ccarrolladams
- Apr 14, 2010
sprior said:I guess I should have mentioned that I finished those shelves yesterday by measuring them individually and they came out great. My continued interest in this thread is in having a more efficient solution for next time.
Hi Sprior, it is good to know you made all the shelves you needed. Now that you measured each individually and obviously cut carefully, you will better appreciate Festool solutions that are as accurate and also more time efficient.
Although a lot of people have found home made solutions, so using expensive purchased components, I encourage everyone needing accurate repeated parallel pieces to seriously consider that set from Festool. Also, do not forget the extensions, because there is a savings buying them included. And, it might turn out the first job after buying the parallel set needs pieces so narrow the extensions are needed.
