CXS Right angle clearance?
grainhaus
Hey guys, does anyone know how tight of an area you can use the right angle attachment in, wondering the dimensions for the right angle chuck with only a screw bit installed, not a chuck. I commonly have like around 2" area to install a screw and am curious to see if this would work .
These might help with your question...
[attachimg=2]
[attachimg=3]
Maybe this will help as well.  Looks to me like the best you can get is 2 3/4" plus the length of the screw.
Here’s a photo of the Festool right angle drive, a SK ratchet and a SnapOn ratchet. The lengths are 2.9”, 2.6” and 1.2” respectively. When I run into tight spaces like this, I’ll start the screw with the SK or SnapOn first and once I have the room, I’ll drive it home with the CXS right angle.
If this is doable or not all depends upon the length of the screw.
