- Oct 16, 2015
Bugsysiegals said:Rick Herrick said:Bugsysiegals said:Why did you decide to buy the Dashboard hinge instead of just using the dog holes with guide rail clips? Also, I didn't know Rockler sells a table, what's it called?
I do use the Parf fence with the Parf guide rail clips, and it does work just fine. But I don't like the way I have to rotate the rail up, slide board out, put new board in and lay the rail back down. The rail, at least for me, has to come up in order for there to be enough clearance to move stock in and out. Plus, sometimes during that process. the rail clip comes off of the Super Parf Dog and its just a little frustrating.
I like the idea of just lifting the rail, change stock and move on. I haven't decided for sure on the Dashboard system but its highly on my 'thinking' list.
This is the main reason which makes me want the Dashboard. It's not terribly inconvenient for me to manually lift the guide rail but would be easier with the Dashboard. I've seen some who don't use the clips and just push the guide rail up to the dogs but I don't have that kind of confidence in that approach so I've been using the clips.
I have constructed my cutting station on a 4' x 8' table that I drilled with the Parf guide system. I use dogs and clips for most of the cuts on this table. The majority of it is with 3/4" sheet goods, so I just place small scraps under the rail near the dogs, to hold it up and to stabilize the rail when the saw is on it. Occasionally I cut some 12mm solid surface material there to, but not at the squared section. Those are usually point-to-point cuts that are specifically not square. I have a simple T-track in the table with an adhesive tape measure and a stop for repeated cuts. It's not really a high volume type of set-up. I have other ways available to do that, if needed, they are just not as handy.
I have also seen a system that eliminates the need for clips by using strong magnets along with steel dogs to attract them. It's an interesting looking idea, but I have no experience with it.
