I am building a small piece and and have a joint which is about 1/16" off center, relative to the piece beneath it (it's a hinged structure, so there are two 'centered' pieces). Normally, I wouldn't care or worry about it, but since it's aligning with a centered piece below, they should really be correct.
All the parts are riftsawn or quartersawn cherry.
My first thought was, remove about 1/16" of material to 'center' the off-center piece. However, it's glued in between 2 other pieces, so it's going to be a chore to clean out those corners.
My second thought was, glue a 1/16" thick piece to the other side of the off-center piece, widening the piece ever so slightly to make it 'centered' again. This seems easier to fit and tune, although the grain match will be a job.
Which way would you go?
