It's takes a little fumbling the first couple of times you connect the parallel guides and guide rail but you get better at it quickly.
As long as you are using the same guide rail and don't change the calibration of the parallel guides at all, you should return to the same set up.
MODIFICATION:
Same guide rail, saw, and blade (or blade with same kerf).
