LLesniak
- Jan 22, 2007
I have a question about a joint that is used in the structure of one of my looms. This mortise and tenon joint is used to connect a large upright (88" tall, 6" wide, 1 1/2" thick) to a foot (40" long, 5" tall, 1 1/2" thick). Think of an inverted T. The existing design uses a mortise 3 1/8" deep, 4" long, and 3/4 inch wide with a matching tenon to join the two pieces making for a strong, stable joint. The tenon is currently cut on a radial arm saw and the mortise on a hollow chisel mortiser. I'd prefer to make this joint using my Domino but I'm concerned that the resulting joint will not be as strong as the existing M&T since the Dominos themselves penetrate less deeply into each part. Would a double row of Dominos hold as well as the M&T? Has anyone in the group used the Domino for joinery of this scale? I've used my Domino extensively but have been working more toward the small end of our loom assemblies than the largest structural joints we create. The attached photo shows one of these looms fully completed with the joint in question at the base of the upright on both sides of the loom.
Any thoughts or input would be greatly appreciated!
Larry
Larry
