PaulMarcel
Well, I did a search here and at tF and didn't find an answer, though I swear someone posted it.
I have an OF-1400 and need longer rods (463147 for the OF-1400). I cannot find the rods for the OF-2200 on the EKAT system to know if they are the same part number (and hence no longer) or if they are indeed different.
If you have one, could you measure the diameter and length of the rods? The OF-1400 has 7.9mm diameter rods (my calipers... could be 8mm
) and are 400mm long. Ideally, the OF-2200 rods are the same diameter, but at least 50mm longer. The MFK-700 rods are shorter, but the same diameter (of note if they are too short.. borrow your OF-1400's)
Thanks!
Thanks!
