I know this is a basic question but can't get an answer elsewhere. Do the Centrotec bits such as the T25 fit other brands of impact drivers. It seems like Festool makes their stuff to not fit other tools, saw blades etc. Thanks, Walt
The Centrotec bits will fit into a 1/4" regular hex chuck but will not lock properly so I would not recommend using them in non-Centrotec impacts. I really don't think Centrotec is made so much to "not fit" as it is designed to be a smooth running, compact , built in, quick change system.
You can get a Centrotec chuck adaptor that you can fit into any chuck - but it makes for a very long drill/driver! (sorry, can't recall the part number and I'm at work).
This thread introduces a topic I was curious about--whether standard Centrotec drivers would stand up to use with an impact tool. I learned the hard way to use impact-rated drivers with my Milwaukee M12 impact tool, so I would assume that the same caution applies to the Festool drivers, in which case whether they fit or not is a moot point.
