Hans Mertens
Most of the time I don't put glue on the domino's. I use it mostly to built cabines and only glue the panels, the domino's are only for allignement.
When I do glue my domino's I put glue on the domino, not in the mortise. You push all the glue down and so it has little effect when you put it in the holes.
When you put glue on your domino and you drive it in the hole, the markings that are presse in the domino will retain enough glue to be effective. That is what these "arrows" are for.
When you use dowels they work the other way around. Here you put glue in the hole and when you drive in the dowel the groves make sure there remains glue on the walls or that the glue can be pushed back up.
I think that 's the reason why Festool hasn' t come out witha glue bottle. This would promote an incorrect way of applying glue.
I use a gluebot, hold the domino lengthwise between my dumb an index finger, put a dap of glue on one side and use an other domino to even it out. Then rotate the second domino and again use it to spread out. Then rotate the first and rub it against the other.
Works pretty fast, one glue spuese, two glued domino's.
