Does anyone use a Digital Inclinometer
NERemodeling
I look at these things every once and a while but never know if they are a gimmic or really accurate enough for saw setup
i don't build furniture but i do a decent amount of trim work and builtins so i care that its going to be pretty darn accurate
i would use it on my tablesaw and to return my SCMS back to 90* after a bevel  (its the makita ls1016, sucks trying to keep this thing square but im stuck with it for now)
iGaging Angle Cube
Wixey WR300
Tilt Box II
the first two run about $26 including shipping, cant find the Tilt Box II for much less than $36.50 w/free shipping
I have the iGaging Angle Cube.
It is certainly accurate enough for construction and some trim work. You will need to check if your blade has a large enough flat area that is parallel to the blade axis. I was able to find that on most 12" mitre saw blades but it gets tougher on 10" blades. Don't forget the blade will have to be spotlessly clean. Your saw will have to be level or you are dead before you start. Is that possible on mobile saws?
Yes, the Makita LS1016 and LS1216 suck. My LS1214 was much better - sold it for the same price as a new LS1216 to a fellow that was returning his LS1216 for the second time.
Do you have an electronic level? I use my Stabila electronic levels more for checking angles than checking level. Seeing the limitations of that technology and then putting it on a 2" base tells you a bunch about the limitations.
My opinion is they are worth the $26, just don't expect it to be a huge solution to the problem.
Greg
Your saw does not have to be level.
Well unless the one you have you can't Zero.
What your suppose to do is sit it on the table first hen Zero it and then stick it on the blade.   It doesn't mater if your table saw is miles out of level you zero the device to your table.
So your can use it on site if you wanted to on a chop saw or table saw.
Jmb
JMB,
I understand that is the theory of zeroing the unit. I have just found it not to work as well in practice as it seems that it should.
I should have been more clear in my statement.
+1 on what JMB said.  You don't need a level saw at all.  I have the wixey and find it indispensable for finding bevel angles on my table saw and squaring my jointer fence.
First you stick it to your horizontal table surface of your saw or jointer and press "zero", then stick it to the blade or jointer fence and it will reference off the horizontal surface you "zeroed" in step one.  Super accurate.
Great info guys, Thanks
I feel it is safe to say that i might rule out the Tilt Box II because it seems to be an identical copy of the Angle Cube and costs $10 more
with your positive reviews of them, im sure ill be getting one.. now its just a matter of which one.
one vote Wixey
one vote iGaging
Ladies and gentleman, do we have a tie breaker.....
I think the "trick" to using these is that when you move the gauge from your tabletop to the blade, it should be in the same plane as it was on the table.  If it leans forward or backward, for instance, it will be in a compound angle relationship to the position in which it was "zeroed".  Practice measuring the same setup several times until you can get consistent results.
I have a Wixey.  Its ok.  None of the device's fault, but my two beefs are: 1)battery is always dead just when I really need it and 2)I start being compulsive about the third digit to the right of the decimal point - which is a waste of time for most work. [embarassed]
nice trick,  that makes a lot of sense  also i wonder if always referencing off the same face of the device would help. with the wixey you only have one set of magnets so you would have to but the angle cube has magnets on 3 sides  using the bottom as a reference on the table top, then the side as a reference on the blade could introduce some error is the case wasnt 100% square
batteries is a big complaint on amazon.. someone said they contacted the company and they were told that the electronics never really power down, just the lcd screen goes out so it is always using power.. could store it without the batteries but that is a pain
you mention several decimal places, online it only shows one decimal place.. is your different?    the igaging angle cube shows 2 decimal places online
John
I have a new Wixey and it works great. I think the dead battery deal from sitting inactive has been resolved.
I find it to be very accurate but as mentioned above you need to take into consideration both x and y  coords.
That said once you know that its going to be way more accurate than a pointer finger on the saw.
i have  a gem ready one.
its great. i often use it. even for working out what slope a wall, floor roof ,stairs ramp etc.
you will find loads of uses for it.
officially how acureate is i dont know but its more acurate than i need
If you are going to spend money for a gauge, I would recommend something like what is shown below. The reason is simply because it will have more uses than the inclinometer. One of my engineering customers bought this for me as a gift because I needed something like it for his projects frequently, and the lousy plastic ones from a drafting supply house just weren't cutting it.
The tool Rick suggests is also more accurate than those tilt boxes.  Don't be fooled by any of these gauge's number of displayed decimal digits.  Many have stated accuracies one digit less than shown (but great marketing!)  For example, I have an old tilt gauge (can't recall brand).  It shows degrees to hundredths.  It's stated accuracy is only ±0.2º, but you have had to keep the packaging to know as it isn't on the device.  ±0.2º adds up.
Actually, just looked up the digital protractors Rick put there.  They are also ±0.2º.
what is the model # on your Wixey?  you say new, did they redesign it or you think they just updated it at some point with the same model/look
Thanks, John
Thats nice and certainly has a lot more uses than the angle box, but what i primarily see myself using it for is returning my miter saw to 90* bevel.. not sure if that could be accomplished with the protractor..
You sure are tempting me to upgrade my old plactic model....
alright, i think it is now narrowed down to these two models
Wixey WR365
  -  claims accuracy to .1*  -  includes level feature  -  seems to be newer wixey model which has no battery issues
or
iGagine Angle Cube
  -  claims accuracy to .2* repeatability to .1*(whatever that means)  -  includes level feature  -  machined aluminum case (accurate to .005 so ive read)  -  magnets on 3 sides  -  resolution to 2 decimal places  -
as always, any user info on ether model would be appreciated!  thanks
Why would you think it wouldn't? The arms rotate a full 360 degrees (actually infinite). You can re-zero the display whenever you want, so you could even use it to find the difference between two angles, etc. I clicked on your amazon link above, and this was also shown. It's only $25.
If it's only $25, get both.  It's so easy to stick the inlinometer on the blade and have both hands to adjust the blade or fence angle.
I bought a Tilt Box about 8 years ago, because it was recommended to me as being better than the Wixley.
At the time, Wixley was having issues with battery run down. (I guess they use a button battery.)
The Tilt Box uses a 9 volt battery.
Also, the Tilt Box has magnets on both sides, and is a pleasure to use.
Never sorry that I spent the extra $$ for it, but it looks like they haven't been marketted as succesfully.
Thanks, John
It's new. Has tilt display and level. Says two year battery life. As far as accuracy I have done all the checks by reversing it like you would a level and cutting 45 degree cuts to compare and it is perfect. I would be lost without it now.
One nice thing about it compare to angle gauge shown above is you don't have to worry about protruding teeth getting in way.
Years ago I bought the Wixey. Compared to nothing it's awesome.
But after getting used to it I wished it had a little higher resolution.
As far as accuracy goes .1 degrees isn't as fine as you think if the joint is long.
Also, short lived hard to find batteries was a real pain.
Then I found out about the Beal Tilt box. Even though the accuracy was said to be the same
the higher resolution would be a benefit and the readily available battery was a big plus.
Higher resolution? When your sneaking up on a very precise angle on something that allows fine adjustment like a table saw then the change from one tenth of a degree to the next seems interminable. You move the tilt wheel on the saw quite a bit an the digital readout remains the same until all of a sudden it's another tenth more. Having a half-tenth display is a benefit ,all other things being equal.
Trouble is all other things weren't equal. There is another specification that isn't shown and that is the how often the device checks the angle. On tools that have crude adjustment like the TS circular saws the device might not be able to keep up with how fast you change the tilt of the saw. You might have hit the right position but the device is still on the previous "look-see" and you continue moving the saw past the place you want.
The there is plain raw accuracy and how well the devise is made. Since I bought the Tilt Box Beal has added this disclaimer to it's description. " The original Tilt Box was advertised as having a resolution of .05 and an accuracy of .1. While this was (and remains) true of many of the units, it is not, we have discovered with time, true of all of them, and so, for the sake of accuracy, we are now downgrading our claims to the more realistic .2 of a degree." You have to applaud the candor.
Accuracy, is there a difference between Wixey's "+/- 0.1" and Beal's (and iGauges's) .2 degree accuracy? Does +1 and minus 1 add up to .2 somehow? That kind of stuff has always confused me. So, it's better for me to take the two devices and glom them side by side onto a 12" saw blade and see how they respond. (I did this test a while back because my neat high resolution Tilt box was behaving suspiciously.) The Wixey slowly ticked of the changes from one tenth to the next and the Beal display changed twice as fast as it displayed half tenths as well. Except when it didn't. Sometimes it stalled and then jumped whole degrees. I was shocked at how erratic the display was. I probably have a bad one but that was the last time I used the Tilt Box. Wherever it is the battery is probably still good.
I know where the Wixey is, I tried to use it yesterday and the battery was dead.
Bottom line, buy the new Wixey and when you use it figure out a way to change the angle in a slow and steady manner for best results. On a TS saw for example clamp the base to a table and rig up a fulcrum and lever so you can move the saw smoothly.
