Brent Taylor
- Aug 5, 2014
I chimed in on a post about how bad the tiltable base is on the Carvex, granted it has it's shortcomings, it's not as good as Mafell, Bosch, PC or even a Trion. I compared it's base to my old Makita's base (4304 BV ), half of the Carvex base equaled about the same surface area of that saw ( I'm only a carpenter/cabinet maker, so it's a rough estimate.), so I tried doing the angled circle cutout as showed in Bosch's ad and was able to do it freehand with no problem (which is a feat in itself with as bad as my hands felt), granted I was only cutting 3/4" ply,I still was able to cut a penny sized hole with ease. Then someone said that you could not use the circle cutting attachment with the bevel base, this is true, but I though that I would try with a homemade jig. I know that it's possible to do, I have done it in the past when I made some table tops, I just did not like the finish that was left using the jigsaw, so I just used the router instead and saved a few steps. The jigsaw was good for roughing out ( as the Carvex would be also ). So I will trying it soon. I would not do an in the field cutout ( sink base or sphere )as that would be to dangerous with a jigsaw cutting at an angle.( a router is the only way that I felt comfortable doing this type of cut ) The Carvex changed the way that I use and think of a jigsaw, and I find myself finding new uses for it everyday. IMHO I think that too many people want things to do everything they want and it has to be now, or else it is a faulty tool or design. It takes time to learn what the tool can and cannot do, in over 40 years of using tool I still am learning who to use them in new and different ways. (rememb er it's fun,enjoyable and safe ) The Carvex is the most advanced jigsaw I have owned ( granted I have only owned 3 ) and I have only just tapped the surface of what this tool can do. The way I see it .it may have shortcomings. ( or I just have not found how to use it in the right manner) If so, sell yours and buy somethin else or add one of the others I talked about above. or take the time to find out how to make it work for you and shair it with the rest of us. Thanks in advance, B
