I have been using the angle guide quite a lot recently. The basic concept is good but the accuracy and, er repeatability are not. As mentioned the scale is small and the slightest knock, even nudging the guide into position, can put it out of setting. Providing care is taken it is good for the unusual angles and for 'rough' cutting. Last night I laid out six 2x4s side by side and flat on my cutting table. Using the angle guide and a cutting guide I gang-cut about 100 18" pieces. Accuracy to 1/8" for this job was not important. However it was fast.
Not mentioned is that you need to have a sufficiently long and straight edge to use as a reference for the guide. The unit needs to be redesigned with a more secure clamping mechanism, possibly with a screw fine adjustment, plus a positive attachment to the rail. I have done the latter (I think using an idea from WoodshopDemos) with a couple of 5/16" bolts and wing nuts. That means I can pick up the rail and guide as one piece thus getting over another aggravation. This fixing in position also allows me to set enough space at the beginning of the guide for the saw to sit and start.
SteveD
