New to Domino 500. Trying to use it on mitered edges at 45 degree setting in walnut. Sometimes the mortises are inconsistent. They're not always the exact same distance from the edge, even though I've set it so that the mortise is nearer the inside edge. I'm using 5/30 tenons because the stock is a bit less than 3/4". What might I be doing wrong? Thanks for any input.
