Mauri Motti
 - Feb 17, 2011
Did a search on it and came to a topic where the matter is described but as the topic's subject is design flaw, I'd thought to do a new topic on this.
From time to time I intensively have to use the Domino and ever to often when I don't recheck the vertical adjustment enough I fail having aligned mortises. Right now I'm on a project that requires 340 dominos and I obviously have to plunge twice that number. The the mating wood is Pine on Oak using the 4X20mm Dominos, so a very small bit this time. After every 10 plunges or so, I open the adjustment knob readjust the fence (when necessary and that isn't so often at all but if i miss the moment im screwed... and yes also on this current project it did happen) and cut the next 10 etc. Brice mentions in the other tread to add a point of friction at the mating surfaces and this is what came to my mind but then decided to search the fog to read and learn about your experiences. As this "only" led me to a topic named "design flaw" here I am. I can't seem to be able to crank the adjustment skew down hard at all as is bottoms out before that's even possible. I did take the skew out to see if I could re-position the lever knob but after removal I can't take the knob off. Maybe I'll have to put more afford on this as I didn't want to force it to come off I then figured I'd better not do this... No, I did not call service as I don't think its a flaw but i'd like to improve it though, Oh boy I'd like to! No, I don't think I plunge to slow nor to fast. It happens to me when using small, bigger or big cutters. I think the moving of vertical adjustment occurs while taking care that the "faceplate" (the on the to be cut wood part) is firmly down to do the the plunge action which, of course, has to be pushed to the wood. I do all of this gently but without hesitating.
Thoughts anyone?
Kind regards,
Mauri Motti
Thoughts anyone?
Kind regards,
Mauri Motti
