Birdhunter said:
To me, the Domino loose tenons have two main functions. One, they keep the two boards from pulling apart. Two, they align the two reference surfaces.
Neither function requires the narrow to narrow technique. Correcting a narrow to narrow mistake requires recutting one or more mortises. You end up with worse precision.
I think the term "measure twice cut once applies here" well at least for my standards anyway. Rough work may not require such precision but, if that's the case, Dominos or mortise and tenon are probably overkill anyway, and dowells or biscuits would suffice.
If the wider or widest cut setting is chosen, the boards or whatever is being joined, have the possibility, depending on the end product, and gluing, of being knocked out, or through acclimatisation, moving out of alignment lengthwise.
When cutting dovetails, mitres, even dowelling, there is no tolerance, which is how a proper joint should be. Well that was the case when I were taught quite some years ago?
It really does depend on the job, and what sort of tolerance the user is aiming for, for me though, there isn't any situation where I'd not want tight precise joints. Especially as I have to give guarantees of usually a minimum of ten years, with our work.
