I've been using my DL 700 for a few months and recently had an application to use the cross-stops. I had them set for the minimum spacing, and noticed the indexing pins were not falling into the reference mortise (8mm) naturally. I had to flex them to have their pins drop. Being suspesious I eyeballed their alignment with the integrated indexing pins. They were not in the same line. Turns out the pin units needed to be rotated 180 degrees so their opposite face was on the slide scale. When I had used them previously they were set for greater spacing and larger diameter dominos so the misalignment was negligible.
