"The fence is the same as the 700. You can upgrade to the 700 fence for around 50$. Gives you the larger window, and the two square cut outs let you see the paddle's. Also the new fence sits all the way down at 45 degrees, so it puts the domino in higher at a forth five. And you can put on the cool sticker!"
The above was posted in another area on FOG. Is this correct? Not having owned the 500 for very long, why would this be a good thing or even worth considering (assuming it's possible).
