I've come from using a Dowelmax jig which is a great little tool. One of its best features is its indexing rod. Precise alignment of dowels along a long edge. The problem with the Domino is when you use two different widths, tight on one edge and loose on another its difficult to achieve the same accuracy ..... So my questions (sorry if this has been covered but couldn't find it) BTW I have seen the very expensive Woodpecker jig that relies on tight mortises
1. If I'm doing tight to tight (I can't see it working with tight to loose) is the cross stop a good tool to use or is it a bit sloppy? Is it worth getting?
2. Has someone made a jig that achieves this purpose regardless of tight to tight or loose? Aligned centered mortises?
3. Is the good old pencil mark on both boards just as good as any jig
