Bob Marino
- Jan 16, 2007
electricald said:Thanks Bob,
I guess one thing is certain, the 700 can do everything the 500 can but not so much or as easy in the reverse? You mentioned doubling up on the tenons using the 500, where the 700 would do it in one go? I guess it is time to watch the videos.
Regards,
Dan
Bob Marino said:Dan,
As most always, good advice here. As mentioned, it comes down to what you want to make with this tool. Most people use 3/4" material and the 6 mm tenon is the perfect size. Remember, with larger, heavier pieces, you can usually double up on the tenons to gain added strength. I think for most users out there, the Domino 500 affords more versatility.
Bob
Dan,
I'm not sure of the exact strength doubling up a tenon would compare to using a single, larger tenon; probably lots of factors apply. The point was that you can double up on a tenon and improve strength. The D can also be used ion 1/2" stock, while the D 700 obviously can't. If it matters, the D 500 is 7 lbs as opposed to 11.4 lbs for the D 700.
Bob
