poto said:
I would have liked to see the mechanism for changing the mortise width. How does that engage to change the side-to-side oscillation of the bit?
I can give you a hint, Poto, but not the complete story. Christian and I stared at the mechanism for some time, and he put it under power as shown in the video, but they drew the line when I asked for a Torx driver.
In the video, the Domino is on its side, with the top facing you.
The part you're most interested in is the hook-like piece of steel you see oscillating as it rides on something-or-other.
The green knob at the lower left rotates to select the width. Inside, the knob is attached to a small shaft with an integral gear. That gear meshes with another similar parallel shaft, and that one with a third. The shafts are clock-like in their size. Each shaft has, on the end away from the knob, a flat. Turning the knob turns all three shafts. At each of the three width settings, one of the shafts is the pivot for the hook-like piece described above, the other two disengage. The varying pivot point controls the width, I believe.
I do not know how this is transmitted to the actual cutter head. It's pretty tight in there, and they wouldn't let me dig deeper.
Ned
BTW, we were warned that when removing a cutter not to put force on the osciilating mechanism. That is to say, with the Domino in working position, don't apply force that would tend to move the mechanism from side to side. Always position the wrench such that the force is 90 degrees from the mechanism's normal movement. Forcing the oscillating mechanism to move can apparently throw it out of adjustment.
