Shutterstile said:A second, related issue is one that I haven't seen mentioned in the Forum previously. I created a jig to allow me to quickly make the double-wide mortises. Basically, it consists of two parallel blocks that serve as stops for the sides of the machine, spaced to provide the correct mortise width. Others have posted similar jigs. The success of this design assumes two critical design characteristics: 1) that the cutter is centered horizontally in the machine; 2) that the base of the machine is square (i.e., that the sides are perpendicular to the face). I'm not sure if the cutter on my machine is centered, because the base is so far out of square that I can't cut a reliable test mortise to check for center. When I set the face of the machine against a work piece, placed in the jig and set perpendicular to the side blocks, the machine doesn't rest square in the jig. I checked the base with a square and found that it is a couple of degrees off. The only way I can think of to compensate for this is to make my jig intentionally out of square the same amount. I'm working on that, but it seems like a pretty crude design flaw for such an expensive piece of equipment.
Sorry for the lengthy dissertation. Thanks for allowing me to vent.
You are assuming the sides are machined square to the bottom and face. They are not. They are not even machined. The reasonl you see this as a design flaw is because you want to use the sides for location and the engineers did not anticipate this type of use. How do I know they are not square? Because I bought Rick's accessory fence and there are little plates designed to permanently capture the location of the plate by bearing against the sides. When I pushed them in place I saw they were not even. When I looked closer I relized these surfaces were left as cast. This does not cause a problem in the manner of their use with Rick's accessory because you can make the plates conform. I had even considered taking the base to work and cutting the sides square but have not done so. And, since they are not square, there is no way the path of the cutter can be exactly in the center of the sides. To use the tool in the manner it was designed to be used it is not necessary to have the sides square and the cutter path centered. If you want to use the sides to register the tool I suggest you start by making sure you are bearing against the face of your work with the face of the tool and pick a single point for registration on either side of the tool somewhere within the area where the shallow dovetails for the outriggers are machined. I believe your accuracy will improve dramatically.
The squareness of the fence is easy to adjust. I have not detected a sagging problem but gravity is not your friend Perhaps a few ounces of lift while plunging may help but I think I would be doubly sure I have the fence adjusted first. Parallelism of the fence to the cutter path and slipping of the fence can be fixed by skuffing up (slightly) the mating surfaces that need to grab each other and/or repositioning the lever to get a bit more travel. I also use a finger and my thumb and treat the lever more like I would a wing nut. this will help keep you from biasing the fence. HTH
