- Feb 22, 2016
To take advantage of the 32mm spacing of the LR32 system and use the rail to guide domino placement far in from the edge and end of a board.
Could be done by clamping a straight edge offset the proper distance but then you still have the spacing issue.
Using the LR32 end stops you can reference off an edge just as when using the LR32 system to drill shelf pins holes or locate hinges but in this case you're locating domino mortises.
