blanning
- Jan 22, 2007
I'm sure this has been discussed before. I searched the forum, but didn't find an exact match. So here goes.
I tried out my domino for the first time tonight. I tried out cutting three M&T joints on two 3/4" scrap pieces of baltic birch plywood. Immediately, I noticed problems with chatter. It was so bad that both the work piece and the domino danced around. This made one of the dominos not line up since it slipped while making the cut.
I'm sure this won't be a problem with hardwoods because they have uniform density throughout the cut. So I'm not surprised that plywood is a little more problematic. I just didn't expect this much trouble with plywood.
I had been holding down both the work piece and the domino with my hands. Clamping down the work piece will probably improve the situation. But I think the forces involved would likely make the wood move anyway. And regardless, the domino machine will still be free to slip from side to side.
Some of the cuts looks good, but others looked downright terrible. I think by setting the domino to make mortises wider than the tenons, it could help the situation. But what I'd really like is a smoother cut that's easier to make.
Does anyone have a technique for this that could make the mortises easier to cut? I'm planning to put some cabinets together with this. And I can't see how cutting mortises in the face of a board will be really possible like this.
I'm using the bit that came with it at the moment. But I have other sizes.
brian
brian
