Dave Ronyak
- Jan 23, 2007
James Watriss said:I think it'd be cool if they made accessory clamps for the hole drilling jig, that would allow the rail to be mounted at 90 degrees to an edge, for just this sort of thing. Evenly spaced dowel joints for large surfaces, cut with a router.
I think it is possible to make a jig to drill a line of dowel holes do as you posited. It should also be possible to do the same operation by setting up the LR 32 on the top of an MFT and the workpiece clamped to the side rail of the MFT, so the router shaft and thus the boring axis is slightly outside of the side rail of the MFT. To assist in lengthwise alignment of the components and the dowel holes to be drilled in them using the LR 32 Hole Drilling Set, it might be helpful to use a stop such as DeWalt's T-Square accessory
to abut the ends of the workpieces to.
Dave R.
