DynaGlide
- May 16, 2017
I'm working on a bench and it's coming up on time to do some joinery. I had planned on using the Domino but am having second thoughts.
The legs are 1.5" or 37mm thick as are the 'rails'. According to the manual a domino at narrow width is 23mm + bit diameter, so 29mm for a 6mm domino or 28mm for a 5mm domino.
I'm not a furniture maker and anytime someone starts talking long grain to short grain my brain checks out. My first thought was to use the support bracket
which has stops at 20mm and cut a spacer block to rest the support bracket on and support the Domino machine during the plunge on the legs. The mortises would be parallel to the top of the bench in this manner. 20mm in with a 29mm width mortise would only leave a few mm before blowing out though.
Not sure what to do on this one if anyone has any ideas. The last time I did a joint like this I used dowels but I sold my doweling jig after getting the Domino.
Thanks,
Matt
Thanks,
Matt
