All of the stock i use for projects comes from rough lumber that I joint and plane. Many times in the past when making panels I have been sucessful in using cauls to hold warped boards flat until the glue dries. I thought I could use my domno to regester boards and eliminate the cauls at glue up. It don't seem to work out. If you regester the domino off the top serface of a board that is not held dead flat then it seems that the hole that the domino mills will not be perpindicular to the surface you registered off from. The results are a very poor allignment of the two mating boards. What techniques are you using to secure your board in preperation for cutting the domino.
