luvmytoolz
- May 17, 2021
That was my observation from the timbermill I worked at when we laminated beams as a teenager, applying to one face only the glue can "skin" over before everything was clamped up, effectively creating a somewhat dry joint, definitely weaker. We ended up going to a resorcinol resin that we slathered on. Whether right or wrong, I must admit I cringe when I see on social media cuttingboards having glue applied to one face and then the pieces are flipped and clamped.bobtskutter said:I read somewhere, might have been on the FOG, that applying PVA type glue to both surfaces makes sure both surfaces are "wet". Apparently you can end up with the glue being sucked into the pores of the wood and get a dry joint. For panel glue ups (and I've not done that many) I apply glue everywhere! Both surfaces and into the domino mortise. I use a small plastic spreader to distribute the glue in the mortise slot.
Bob
