- Oct 16, 2015
I believe that about you [member=57948]ChuckS[/member] that is for the benefit of those who come along later.
[big grin]Crazyraceguy said:I believe that about you [member=57948]ChuckS[/member] that is for the benefit of those who come along later.
Jim_in_PA said:I will add to this conversation (and it may have already been mentioned, but I read quickly) that one should also choose which Dominos actually need glue. I don't, for example, use glue on the Dominos for a large panel glue up (such as a table top) as they are employed primarily for alignment of the top surface of the panel to reduce the amount of work necessary to level it later. I do use glue if a Domino is participating in joinery on smaller parts as they are then being used as tenons in mortises for strength, often in cross grain situations. You don't need a "yuge" amount of glue for this as has been noted.
Woodboss said:Hi just wanted to mention if your boards are flat and straight dominos are waste of time on a panel glue up
Crazyraceguy said:chris s said:In looking at the picture I see a rabbit on the bottom edge of one of the pieces. I am wondering if this is causing the joint to bow upward and open. Are the dominoes install during the dry fit up? If so and the dry fit up is ok then the problem is in the clamping or as others have said to much glue.
Agreed, at least partly. The contact with the long edge of the rabbet would create a bow downward, but that should be negated by the clamp bars. Ultimately though, there was no mention of a bow, just not closing.
Tite-bond 3 is a fairly slow setting glue, as far as typical wood glues go, but it will still cause swelling/tightening of the tenons.
Nine Dominos may be too many, especially if your boards were nice and straight, in the first place. This increases the difficulty of pressing this all together.
As an aside,
unless there is some specific reason that you can't do it later, I wouldn't cut the rabbet first. You risk denting the edge because of the lack of surface area on that edge.
Also, your clamping pressure would be far more even if you clamp from both sides. All of yours are on the bottom, a few from the top, could straighten things enough to close up better.
This was all 2 months ago. Did you finish this project? Better results?
RJNeal said:What Chuck said, sometimes when I’m using dominos in this application, I dont even glue the dominos in. They are there for alignment only.
Crazyraceguy said:That sounds good in theory, but "glubrication" adds complexity.
Many things that go perfectly as a dry-fit aren't as simple once the glue gets in there. Gluing more than one seam at a time exacerbates this issue.
Mini Me said:RJNeal said:What Chuck said, sometimes when I’m using dominos in this application, I don’t even glue the dominos in. They are there for alignment only.
I have never understood why gluing Dominos is either needed or desirable. Perhaps it is because I see them as an alignment tool and not adding strength to the job.
Mini Me said:I have never understood why gluing Dominos is either needed or desirable. Perhaps it is because I see them as an alignment tool and not adding strength to the job.
Cheese said:Here's a joint I constructed from fir 8 years ago that I intended to break apart to monitor how evenly/unevenly the glue was applied with a flux brush and to see what parts adhered to each other and how strong the adherence was.
