Folks,
This is another of my "small workpieces" question (following up on the thread below). I'm wondering whether it's possible to put an 8mm domino into a board that is 11mm thick (the material is sapelle, a hardowood similar to mahogany), or whether this will make the joint liable to split. I could use the smaller 5/6 mm tenons, but for various reasons I need a 50mm long tenon, and the 5 and 6 mm dominoes don't come in that width AFAIK (and I don't have any if they do).
I tried to do use an 8mm tenon and found that there was very little material left on the faces parallel to the domino (1.5 mm per side) and it's easy to tear that off, but once the domino was in and glued, it seemed solid and and I not feel any give when pushing the domino pretty hard in the direction where the joint might split.
Any input would be welcome.
Thanks,
Nike
Thanks,
Nike
