James Watriss
- Mar 4, 2008
So, this is a mod of an existing mod... whatever that means.
I was mortising into end grain of white oak today. Rough stuff, and the machine really didn't want to hold still. Now, I'd had the idea to clamp the domi-plate down already. But futzing with the domino and an F- clamp on the wood was a real hassle. I had to turn the machine off while messing with the clamp, etc, to keep the spinning bit from dancing on the wood. I knew there had to be an easier way... and then I had the idea to screw a piece of T-track to the plate, so I could use the clamps that work with the rails and the MFS. Now I can adjust the clamp and move the machine without having to stop and turn it off.
I had to use countersunk screws to clear the clamp in the track, but the idea worked like a charm.
I did notice something interesting once everything was clamped up... the dominoes fit in easier. I'm guessing that when the bit is doing it's thing, every time it wiggles to one side, it nudges the machine a bit to the other side, and as a result, the mortise ends up not quite as wide as it should be. Bolting the plate to the mortiser, and clamping the work to the plate, seems to help.
Anyway, this is clearly going to help a lot when it comes to narrow stock, so I figured it would be worth posting. It's also a decent, albeit less comfortable way to hold the plate down and up against the work, instead of using the clamping elements knob.
Only problem now, is that I KNOW the marks on the base plate aren't properly aligned. All of the joints are flat flat flat... and slightly to one side.
F-Bomb.
Two steps forward, and one back... but I don't want to warranty the pin fence. I like pins. [unsure]
Pictured here with the poor-man's Vac-sys.
F-Bomb.
