VW mick
- Apr 27, 2014
VW mick said:Ha ha
No that's the side ,prob not clear in my photon. I'm going to add a drawer front that is just the drawer box
grbmds said:Since acquiring my Domino, I made drawers for a work table in my shop using 2 Dominos per corner on a drawer that depth and 3 for a deeper drawer. The 5X30 Domino will certainly add strength. I would not depend solely on the pins and glue, especially if you are planning on using the drawer to hold anything substantial. carlb40 is right, though, about the front/back comment. That is how I've made my drawers. I also have added a front to my drawers, choosing to install them with full extension metal drawer slides. This covers up the butt joint in the front and the back is hidden anyway. You may already know all of this, but I couldn't tell from your post.
roblg3 said:mortice and tenon joinery basics is tenon 1/3 the thickness of material. For 12mm material, 4mm domino is suggested.
builderbob said:But if the drawers are already constructed you'll never get the 4mm cutter to make a deep enough cut to make a difference. At that point I'd use the 5mm tight setting and cut off your excess. If you're able to take the drawers back apart then yes I would use a 4 on 1/2" material.
