Chris Hughes
- Mar 15, 2008
Someone PM'ed my a few questions about how to cut out the back of a drawer for undermounts a little while ago. I answered the questions but never heard for him again so I don't know if he understood the technique and thought it a waste of time or if he didn't understand it at all. Either way I thought I would put together a pictorial and a brief explanation. It a very quick and easy way to knock out the slots in drawers whether in the field or shop.
One of the benefits of the Festool system is the ability to do high quality work in the field without the overhead of the shop. The ability to build strong draws without fasteners revealed using the Domino. A trend in cabinet design has been the replacement of side mount slides with undermount slides. The use of this hardware is as straight forward as any. The two brands I use and see most are Blum and Salice are almost identical in drawer sizes and requirements for the cabinet sizing.
One the questions asked was, "How big is the cutout in the back of the drawer for the hardware to pass through?" For those new to undermount hardware, the drawer box sits on top of the slides and is fastened only with a release on the front and a barb at the back of the slide that protrudes into the drawer back to keep the drawer from tipping. The width of the cut out varies a little between brands, but I have found that 1 1/4" from the inside of the drawer sides.
The next question was, "how do you cut a 1 1/4" slot through the back of a assembled drawer box?". I have observed many shops using a table saw and dado set with multiple passes to accomplish the feat. When I first started using undermount slides that is how I set up as well. I found the process problematic. If the sides varied in width, if the material depth beyond the drawer bottom varied, setting up to cut the left side versus the right, the availability of the stable saw and dado set when in the field were all issues I found with the common technique.
I found that I could simplify the work of the cut out by using a flush cut hand saw and a router with a large dovetail bit.
step one. Flip the drawer box over and rotate the back of the drawer towards you. Measure from the inside of the side and mark at 1 1/4" a square line and extend down about a half an inch. This line is the guide for the "control" cut toward the inside of the drawer back.
step two. Using a flush cut saw, cut along your line until you reach the drawer bottom. This will prevent tear out.
step three. Set up a router with a large diameter dovetail bit. set the router on the drawer sides to set depth of cut. Plunge bit until it makes contact with drawer bottom. You should be able to move router freely while making contact with bottom for proper adjustment.
step four. Move the router to the outside of the drawer box to cut a horizontal control cut, similar to the technique we would use when cutting a dovetail joint. This will prevent tear out on the back of the drawer. After the control cut in complete, move the router aback to the inside of the drawer bottom. Start the cut away from the drawer side and the control cut. This allows you to walk the bit to the control cuts, kind of staying inside the lines. Move the router back and forth between the margins. Once the bulk of the material is removed make a pass along each control cut for cleanup.
Bob's your Uncle, you have made your knock out without a table saw and it was both clean and quick.
The only thing you have to do next is attach the quick releases on the front bottom side of the drawer and drill a couple of hole in the back for the barbs on the slide.
The releases are self explanatory and vary between brands so I won't go into that. The holes in the back vary as well between brands in their placement but most use a 6mm or 1/4" bit. There are jigs available for placement but I have found it very easy to place the holes by sliding the drawer into place and giving a light tap to indent the drawer back. Using a 1/4" bit, drill a hole about 3/8" deep.
