[member=10616]Claimdude[/member] - seven questions:
1. Judging from your photos, the Rockler version appears to feature brass or bronze bushings for the interface between the chuck carriage and the steel guide rods. As was discussed earlier, the UJK version features bronze Oilite (oil impregnated) bushings. The advantage of these are that they provide continually lubricated operation while reducing to a minimum any play between the carriage and the guide rods. Are you able to discern any noticeable play between the chuck carriage and the guide rods on the Rockler version?
2. I note the Rockler version features a brass thumbscrew to lock the chuck carriage against one of the steel guide rods. I assume the use of a brass fastener is to prevent marring of the relevant steel guide rod. In practice, does use of the brass thumbscrew do an damage to the associated guide rod?
3. Do you have the capability of being able to determine if the guide rods are accurately parallel/coplaner/inline with with each other? If so, how are yours?
4. The first run of the 2nd Generation UJK-branded drill guide suffered from a problem with the rubber base which produced a wobble. Does yours suffer from this problem?
5. Assuming you have access to a caliper, what is the diameter of the guide rods? I'm wondering which size stop collar is compatible (since it should be a simple matter to acquire a second collar should two be desired).
6. The hex shaft connected to the chuck on the UJK version is Centrotec-compatible. It appears from your photos that the Rockler one may be as well. Can you confirm?
7. Do the graduations on the angle adjustment castings appear to be accurate and in agreement?
Looking forward to your reply!
