Drywall
saands
Hello,
I am new to this Forum and I just wanted to thank everyone for their valuable contributions. I also wanted to ask a question. I am wondering if anyone has used the ETS EC 150/5 sander to sand drywall?
Thanks!
saands said:
Hello,
Thanks!
I used mine last week for a drywall section repair, after a lame plumber cut the hole all wrong. It shreds the material so use a finer grit, as in over 220 grit, 320 grit would be a good place to start. Turn the speed down, along with suction. Abranet, or Granat net would be best to use, but anything that sands will get the job done.
If doing entire rooms or whole house, you might struggle to get it flat, especially if it is your first time. A regular manual hand sander on a pole is more assured to keep the wall flat.
How you do the mud is important. Thinner is better and the longer the knife you use the better for skim coating. Many folks will apply a following layer of very thin mud with a paint roller, then knife it.
I regularly use my ETS150/3 to sand drywall.  Love not having to blow boulders out of my nose at the end of the day.
Sanding drywall?  I have not done that in years.  I just use a damp/wet rag to wipe the dry drywall mud.  A wet rag smooths drywall mud great.  Maybe on the very last coat you might hand sand with a piece of fine grit paper.
Used the ETS EC 150/5 a number of times for drywall sanding, I was totally convinced after redoing a ceiling.
I don't do enough drywall to warrant a Planex - nor am I a painter (though I sometimes have to take on that role) so for me the ETS EC works really well, lightweight and agile.
I use my pro 5 and DTS for the small jobs and inside corners. Planex for the big flats.
The EZ is on recon currently paired with the CT AC
