Corwin said:
Keep in mind that may of us want to attach a Systainer and/or Sortainer to the top of our vacs and then attach the cyclone's container on top of that stack.
Corwin,
Also keep in mind that if you put your dust deputy set up on top of a systainer, the hose supplied by Oneida may not reach between the vac and the top of the cyclone.
I have the old bucket style, in fact I just installed my third one this weekend. I used the large hose that comes with the boom arm to go between the vac and the top of the cyclone. The Oneida supplied hose was to short.
I believe the buckets are a little taller than the systainer style. That is just an observation from the pictures, not a measurement. And I don't know the length of the hose that Oneida sends with the Festool systainer type bucket either. This is an unwieldy connection though since there is 90 degree bend out the side of the vac turning upwards, and another 180 degree turn at the top to come down onto the cyclone. A stiffer hose works better since it won't collapse as easy under vacuum as it goes around the bends.
The hose that came with my last Dust Deputy was plenty stiff and won't collapse. It was just too short, so thats why I used the 50mm hose supplied with the boom arm for this connection.
On my first Dust Deputy setups, the Oneida supplied hose was more flexible and easier to collapse on the sharp bends, and it was too short. On those set ups, I used 2 1/2 inch wire reinforced clear hose like they sell at woodcraft. And even it scrunched down under suction as it made the 180 degree turn at the top of the cyclone.
The best set up would be to have a large radius solid piping at the top of the cyclone that made the 180 degree loop and a large radius 90 degree coming attached to the vac pointing up. then the section of hose between these fittings would be easier to manage and could be just about any type of hose. Of course you would still have to adjust the length according to accommodate the extra systainers added to your stack.
On the system I set up this weekend, I used the old style double bucket attached to a board that latches into the systainer pocket on top of the CT. I used the Boom arm 50mm between the vac and cyclone. I used 2 1/2 inch clear wire reinforced hose from the cyclone up the boom arm to the tip. At the tip I threaded it through a three inch PVC 45 degree street EL that is mounted to the tip of the boom arm. The Street EL supports the bend and keeps the hose from kinking as it makes the turn towards the floor. I also stripped back the wire from the wire reinforced hose on both ends to connect to the Festool ends to complete the circuit to maintain the anti static properties. I simply wrapped the wire around the Festool plastic and clamped it with a circle clamp. Finally, I attached a 15 foot electric cord from the vac up the boom arm to the tip with wire ties. And attached the Festool cords to both Festool hoses (27mm and 36mm) with velcro strips.
When you attach the Festool hose to the boom arm for use, it has much better reach since it attaches on the end of the boom arm. Even though my vac is mobile, It has enough reach to use everywhere I usually work without moving it. And I tested the suction to see if I could notice any reduction. Set up as described, I still have to reduce the suction when sanding with my ETS 150/3 to make it "float". I believe the reduction in suction is minimized since the hoses start large at the vac 50mm, then through the cyclone, then to 2 1/2 inch, then to the work hoses. And total length is about 25 feet. The whole set up took about two hours including assembling the boom arm, cutting the mounting board.
I will try to add some pics but it's a pretty simple set up as described.
