I received my Festool specific Dust Deputy yesterday and had a chance to assemble it last night. While I have yet to use it, I'll admit I'm a little disappointed by a few issues I encountered.
I have a CT22 vac with a Sortainer installed on top, along with the boom arm and a 36mm hose attached to the boom. I planned to put the Dust Deputy on top of the Sortainer. After reading here that installing the Dust Deputy on top of the Sortainer might be an issue I contacted Oneida and was told they were correcting this issue.
Here are my observations (not major problems, but just want you to be aware):
- As you can see from John's post above, the box is not translucent as originally advertised. Not a huge issue, but it will make it a bit harder to know if the box is full.
- The package includes 2 90 degree elbows, although the instruction manual says only one should be used for the CT22 or CT33. Oneida supplies copper tape and instructs you to run the copper tape inside the elbow (for static connection). The supplied elbow has a sharp 90 degree turn, and I wound up tearing the copper tape upon my first try due to the sharpness of the turn. Here is the picture:
- When I tried to put the Dust Deputy on top of my sortainer, I immediately noticed that the relief cuts that Oneida made to fix the Sortainer/Systainer mounting problem, were not in the correct position for a good mount (this can be fixed by removing more of the material, but that leaves the one tab smaller than it should be, in my opinion).
When I secured the side clips without any modification, the box moves toward the front which results in the front clips not being able to click into the locked position, resulting in a less than solid connection:
- Next, I tried to connect my 36mm hose to the cyclone. Unfortunately, the cyclone connection is too small. After comparing my 36mm hose end to the 27mm hose end, I found the problem - the 27mm hose end has an opening around the actual hose, that allows the hose to slip deeper onto the cyclone connection, where the 36mm hose does not (this is only a problem for those who might want to use the 36mm hose):
27mm hose end:
36mm hose end:
I was able to use the 2nd 90 degree elbow to make that connection, which might be less than ideal, but it works.
- Lastly, I was a little disappointed that although the initial pre-order offer did mention the $10.50 shipping amount that I was charged, subsequent advertisement emails I received from Oneida (and there were quite a few), mentioned FREE shipping. I would think that offer should have been extended to those that pre-ordered and waited 2 months, but then again, that is only my opinion.
Overall, it appears to be a good product that hopefully will get better with time. Hopefully Oneida will continue making improvements and future purchasers won't experience any of the minor issues I did.
Thanks, Harry
