Dust Deputy on CT22 running 100mm hose
type
Hi im short of space and have been thinking about an Ultimate Dust Deputy to go  on my CT22.
I have a Kity 1619 table saw that I dont use much but do like a clean workshop. Can I use a reducer to go on to my festool  standard hose to connect to my 100mm table saw?
Im on a budget but Ive looked at cheap SIP  too
http://www.toolstation.com/shop/p28...=28641&gclid=CjwKEAjw1PPJBRDq9dGHivbXmhcSJAAT
or the above Oneida.
Any thoughts on experience with both/ reducer sizes and  places to buy would be appreciated.
      If that is a 100mm diameter hose connection or hose that you would like to connect, the problem will likely be that you won't get enough air volume moved with the CT to make it work.
Hi Seth thank you for your response so do you think Im better off going with the SIP?
kind regards
rich
