Festoller said:Just when I've finished my Dust Deputy Systainer Oneida introduces their own ?Sysdeputy?. Great! [blink]
The whole thing works perfect, just take your time to really make it airtight!
I would think that a bag should not sucked [eek] up as there should be no airflow in the collector. If there were the dust itself would not stay there.Festoller said:Jerome:
I guess because of the strong airflow the bag would be sucked up. I thought about that too, but you'd have to find a way to attach the bag to the wood box.
bobbobbob said:To eliminate the bag being 'sucked up', add a small vacuum line to the container. Source can be from dust collector itself. This would create negative pressure between walls and bag and keep it in its place.
Festoller said:Looks like his connection from the cyclone to the bag is fixed and quite long, that might limit airflow somehow.
My personal observation is that there's a certain amount of dust starting to flow through the cyclone when I start the Midi. Also the sucktion is quite strong and can compress the systainer if you block the end of the hose.
Although the other versions here on FOG never showed a bag, I'll just give it a try later today anyway.
Michael Kellough said:Snip.
The simplest solution to bucket collapse remains what bobbobbob posted back in 2009, just use two buckets, nested.
