six-point socket II
- Jun 26, 2016
also works with Festool OSC 18 LI and current Würth Multicutter/Multitools.
So I wrote about my latest sanding extravaganza here:https://www.festoolownersgroup.com/home-improvement-other-projects/'quick-and-dirty'-basement-door-repair/msg605171/#msg605171
Due to some unfortunate miss information I was told this product didn't exist, when in fact, it's available since January 2020.
The 92602102000 Fein dust extraction set. Price is about 40,- Euro, MSRP.
(The story is as follows: In the beginning of February I contacted Fein about a dust extraction solution for the cordless MultiMaster QSL - I was told by two different employees that it doesn't exist. One even told me that would only ever happen if sales of the cordless MultiMaster QSL go up/ justify such an accessory. So I did the staircase, and after finishing it, talked about it to friend. Who in return showed me a PDF with exactly this dust extraction kit and that it was available since January. I nearly exploded.)
Any way, to have this at hand for future tasks/jobs, I bought it immediately.
Typically Fein. Neatly packaged, looks nice.
Also typically Fein, thought through right to the hex key: The short end is long enough to tighten the screws completely, without catching on the tool mount. (Since the longer end is reduced in size for adjusting the dust extraction port.)
With dust extraction kit,
as well as without.
Not sure if I'm leaving these screws in place, maybe they will rattle loose over time - I don't know. For now I'm going to try it that way.
What can I say, it works. If I had to find something negative about it, it would be the 80mm edge length. 93mm is a vast standard.
( But theres a solution, a friend came up with: Use the 93mm delta sanding pad by Bosch, a protection/interface pad by Mirka and mesh abrasives by SIA.
https://www.bosch-professional.com/...-fuer-multifunktionswerkzeuge-2593343-ocs-ac/
https://www.mirka.com/Pad-Saver-90x90mm-12H-1Pack-8293012111/
https://www.siaabrasives.com/de/de/siaabrasives-ocs/holz-4367/7900-sianet-17734/ )
Fits the accessory box. (OK, mine is definitely filled to the max, but it will fit!
Yes, I could have used this kit much sooner ... [scared] [big grin] [wink]
Kind regards,
Oliver
as well as without.
Kind regards,
Oliver
