My guess (haven't tried it, just looking at numbers) is a 1600w generator will do it fine, a 900w might be okay if you keep the vacuum turned down and a 600w will be fine for the sander only. The CT Mini is 400-1200 watts depending the setting you use and the sander is 310 watts.
