Gargoyle said:
Leakyroof, which paper do like to use for sanding painted walls and ceilings with the Planex? I just purchase the Planex last Sunday and have tried crystal in 100, 150,180, 220, and 60 and 80 in the granat. Both papers load up quickly but I have had better success with the Granat. It seems I'm spending more time cleaning or changing the paper than sanding. Can you offer any tips? Thank you, Gargoyle.
leakyroof said:
Although I don't like using a ETS 150 overhead or on a ceiling for long periods of time if I can avoid it, I can't say I find that sander too heavy to use on walls/horizontally. If you drop to a smaller pad size with either sander you posted about, you already know you're losing time as well since the 150mm/6" pad was covering your wall faster. [embarassed]
I use a Planex on walls and ceilings where ever I can fit the sander. It speeds things up really nice.
If you're not stripping paint, then I would hope the ETS 125 would be okay for you.
That's weird that the Granat is even loading up on paint. I was just skim sanding older latex to get a good scuff for repainting with either 150 or 220 Granat and I had zero corns or stuck paint on the Disc when I was done. How deep were you going with the Planex, like multiple layers of paint
I have managed to load up Granat with not-fully-dry Durabond/compound, but that was my fault, not the abrasive's. [big grin]
Depending on what's stuck to the abrasive disc, I either use a Crepe Rubber cleaning block like the kind that you'd clean a sanding belt with, or maybe Denatured Alcohol with an old toothbrush. I gave up using rags since the Granat is usually so sharp that it cuts a hole right into cotton while you're trying to scrub off something on the disc..... [eek] [eek]
Sanding schedules for me are usually higher grits than 60 with my Planex. Haven't needed to break out any Saphir or remove a textured ceiling or wall finish, but it's nice to know the sander is ready for the job.
Drywall compound/mud, 80 grit for rough work or plaster repair/blending , or higher as needed.[ I never seem to be facing a wall that's newer than 80 years old.. [cool]]
Final sanding, 150-220 for compound. I have all 3 Planex abrasive types on hand, but am usually using Granat for everything so far
I didn't know you could get any older stock of Cristal that would even fit the Planex, did you mean Saphir by mistake?
