Thanks to amazing customer service from Woodpeckers I can replace the Rockler phenolic table with a bigger better WP table, which will allow me to finally make use of the old (new) SmartLift.
Removing the wood screws I used on the Rockler table was uneventful. I expected to snap some heads.
For the WP phenolic table I found a better option for the screws. Kreg 3/4” pocket hole screws for hardwood. The threads project less and the pitch is finer. The table is 3/4” thick but with the powder coat the mounting brackets are .14” thick.
Drilled 7/64” pilot holes. Used tape on the bit to indicate maximum drilling depth. A funny thing happened when drilling the pilot holes, the swarf filled the flutes to the tape and backed up in the hole, got too hot, and a puff of horrid white smoke rose up from the hole. Actually not funny. Toxic.
The screws tightened perfectly at the #10 clutch setting on the CXS. Beyond hand tight. The #8 wood screws put into 1/8” pilot holes on the previous table were okay but I have twice as much confidence in these fasteners.
