Programmergeek
- May 2, 2007
Wow this thread took off I have a fein, a mini and a ct22
The Fein is the quietest nest the mini then the ct22
Now for me the good and the bad. My Fein has broken twice, apperenty sheet rock dust kills the motors. Neithor festool has broken althought it is newer. I usally grab the mini, then the ct22 if a bigger job, then the Fein last. I don't like the fein because it is a pain to roll around if there is anything on the floor to get under a wheel it topples over. Also the fitting on the hose does not fit as much as the festool and the varable speed is a must for me if samding.
The festool packs the bags tigher and is a better design here the Fein never packs the bag you get it about 85% full then it looses suction.
Price the Fine is better here since you can use it as a wet dry (you need to buy the buckes for the festool). Also the hose is bigger than the stock hose on the Festool. Overall a better valuse out of the box. But the Festool is better I think since you can get a lager hose, is antistatic, has suction control and easer to roll around. Also the form factor is better to put boxes on or store.
Hope this helps,
Jason
Hope this helps,
Jason
