Festool 482107 Guide Rail Connector, distance between the screws?
threesixright
Anybody that has these connectors, could measure the distance between the screws (center to center), as on the picture?
Total length would be also great.
Much obliged!
Roger
Length between the centres you've marked in red is 80mm. Between the two centre fixings is 96mm. Overall length is 315mm.
ben_r_ said:
Whatcha up to? Why were you lookin for that info?
Hehe, first to ask [wink]. Curiosity killed the cat!  [tongue]
J/K as side.
Was looking to create a poor men's  square.  Basically taking the rail connectors (#482107) and put a t-slot profile (400mm) perpendicular to the rail . Now the slots needs to be, according to the measurements 80mm apart. Basically needed the info to check if I could find a t-slot rail where the slots are 80 mm apart.
