TomGadwa1 said:
First of all make certain that the screw is backed off almost to the point where there are only a few threads showing above the arm of the clamp. Next insert the clamp into the rail slot after it hopefully has been passed through an MFT3 table. Now this is important hold the part of the clamp that passes through the table to the rail with one hand and snug up the arm as tight as you can toward the rail with the other hand. Now while still holding the arm snug tighten the clamp firmly. This sounds much harder to do than it is with some practice. If you do it as I have described above the Festool clamps of both quick and screw types will NOT LOOSEN UP.
I always have started them backed off all the way. Its just habit from using other F clamps in woodworking for years.
In this case I wasn't using the MFT table. I have used others without the MFT with no problems.
I am pretty sure it isn't a problem with how I am tightening them.
I will have to go back and play with them some more. The more I think about it, I think it was just the one clamp.
[quote author=Sparktrician ]
One thing I learned from Sedge regarding reattaching the splinter guard strips is to replace the adhesive with another material like double-faced tape or the tape that Tom suggested, and when you reattach the strip to the rail, move it out 2-3mm so that the next pass with your TS55 re-cuts the edge of the splinter guard strip. Once you do that, it will be accurate again as an alignment gauge. [/quote]
I started moving it over, but I need a new strip now, no more room to move on the ends LOL I will have to try the tape and order some new strips.
[quote author=farmer]
As far as the clamps loosening up, try everyone's suggestions on tightening them properly.... but if it still will not stay put you may need to ask festool service for a replacement. You may have gotten duds. Out of 4 F clamps that I originally purchased, I had one that would just never stay tight. I thought it was operator error for a while, but it always happened to the same clamp. In fact, if I tried to over tighten it I would watch it start to slip as I cranked down on the knob.... it just would not bite! So, I posted a question on here about trying to make it work properly, thought maybe others may have had the same issue and there was some simple fix... but in the end I ended up having a replacement sent to me - and it works just fine. [/quote]
Thanks, I will play with them more and see if I can notice them slipping like you said. I sent Festool service an email earlier in the week and have not heard back at all.
thanks everyone for the responses....scott
