Sanderxpander said:
I have to wonder how many people actually use the CMS router option as a mobile unit. You can get cheaper and better router tables/fences for less money than just the CMS router plate kit and while the OF1400 and 2200 are great routers, they're kind of overkill in a table.
Portability seems the main advantage of the CMS over dedicated tables, even though many green goggled fans use it stationary.
Small/Compact are not exactly one in the same as portable or to say Portability is not exactly the reason some people want small/compact. I think a lot of folks simply want to be able to nicely pack it away in a cabinet when not in use.
Still, I can't see I've seen anything like a CMS for routers. You have the basic "table" deal you buy at the big box store that doesn't do much but hold a router. Or you get into big DIY assembly of random parts that people build. I would be curious if anyone can point to something that is the same as a CMS router setup, not a "buy this", "add this companies lift", etc. The turn key aspect of it is a winner, and the addition that you could swap it with a saw and such is what put it over the top. Just adding up various parts to build a nice router setup, I don't see the CMS as being much more expensive or more expensive at all. It's not like you can buy just a lift and call it a day. Similar to people who think they can build a MFT for less. You can't. You can build a thing for less, but it is a matter of what did you trade off.
I would say an OF2200 is over kill just to mount in a CMS, but that is where if they made a dedicated unit then they could save on a bunch of cost. But of course it gets back to the whole benefit is that you still have a router to use for anything else and when you need it in the table, you have it. For a lot of folks the hassle of swapping the parts around is worth it if it means you save the price of buying multiple routers, or space savings, etc.
I'm just a person with a small house, and not much room for a workshop when all is done. When I get my house done, stuff will either need to be able to be stored away for periods of time, or be something that is easy to resell. This rules lots of big things are out, and DIY home brew stuff is out. If I had room, I would just skip most festool stuff and get a CNC router setup I could fit a 4x8 sheet in. Net cost wise it might be cheaper than lots of saws, routers, lr32 setups, and so forth. I just don't have the space.
