Hello all.
first post here. looking forward to gaining knowledge from other festool users.
My question relates to the domino. I have owned my domino 500 for a while now and absolutely love it. I recently built a credenza using the domino. For the credenza I used walnut plywood and all the joints were butt joints with I believe four domino tenons in each joint. The domino was set on the tight setting. All went well as there are no movement issues with the plywood.
I have seen photos of people using this method for solid case construction whether it be butt joints, mitres, etc.
can you use the domino for solid case construction and it allow wood movement? if so what spacing and how to glue? to me it doesn't seem like it is possible but i could be wrong. Wouldn't be the first time!
thanks for any input in advance.
