Festool hose kink
rjwz28
While I was heating up the heat shrink tubing around my braiding and vacuum hose, I melted it some what and now has a kink in it.  I'm not sure how much it affects the suction as I felt hose opening and felt ok but can't tell if the sawdust is passing that area fine or not.  Should I try to splice it and reconnect or leave it as is?  I really don't like how it looks like that.  Any ideas how to splice?
thanks,
Rob
Self-amalgamating tape??
I know there's been one or two post re' fixing small holes.
Richard
(edit:  sorry you've got a kink - not a hole.)
Where is the kink?
If you wouldn't lose too much hose, and you really don't like the way it looks, it's a trivial task to disconnect the hose end, cut the hose, and reconnect it. You just push the tabs on the two sides in with a flat screwdriver and pull it apart, unscrew the end off the hose, cut the hose, and re-assemble.
You're not the only one that did that ...  [crying]
GarryMartin said:
Where is the kink?
The kink is 10' from the end!  ha ha ha.
thanks
Does Festool or any other manufacturer make a coupler to join two hoses together?
thanks
thanks
If you're talking about 27mm hoses, there's an easy way.  Just get a second small end (487071) and use it to replace the 50mm end that goes into the dust extractor.  Then get a copper 1-1/4" coupling at your favorite plumbing store.  The tool end of the two hoses will slip in securely into the copper coupling and the copper retains the anti-static properties of the hose from end to end.
[smile]
