Banana
- Dec 21, 2019
Found this thread through an image search and had a follow up question:
Does anyone know if there is an internal physical difference between the #487555 (female) and the #487554 (male) Grips ?
I.e. - Can both be opened? Are both the same inside in that you can either slip in a hex bolt head or instead drop in a hex nut? Or is the hex sleeve different internally (like perhaps the female grip uses a square nut?).
Many thanks.
Many thanks.
