semenza
Let's quit debating abut the debating of the new Systainer problems in this topic.
Thanks,
Thanks,
Spandex said:[...] I don't think you're going to trick them into thinking there have been thousands of complaints, just because the same handful of people complained thousands of times.
woodbutcherbower said:I’m sure it’s very nice and all, but the only level I’ve ever trusted is a Stabila. A small torpedo level like this is also invariably used to level something relatively small. Having to use the whole Systainer kinda defeats the object. Plus - the slightest amount of flex or locating accuracy on the mounting mechanism will result in an inaccurate reading. The promo pic doesn’t exactly inspire much confidence;
Hard pass from me.
woodbutcherbower said:Spandex said:Lol. No, it’s just stored in the handle. The whole thing comes out to use it.
Doh. I feel like a bit of a chump for not realising that [big grin] So now I understand that, the fatal flaw for me would be that I’d have to bring that one specific Systainer into every job I do. All my small levels are in my hand tools box, and the big stuff sits in the ceiling-mounted van rack holding my rails. Neat idea though, and I see the appeal.
Mr Speaker said:I'd like to interrupt the thread on systainers to let you know I bough the LESSYS-FT1 for a number of my friends for Sinterklaas. I found it here on FOG while procrastinating. I think it is great to have a decent leveler always with you that does not get damaged in the general tool case. I'll use a laser when I need a larger range like meters on end. But this nifty leveler is one to always have with you and you always know where it is. Btw, How much accuracy do you need. On site, with my projects, I often end up referencing the ceiling instead of leveling because it is more important to look level that to be level (e.g. when putting up acoustic treatment, acoustic panels). So even when I have an accurate laser with me, i sometime use the ceiling because that will make it look level.
memtew said:I've got mine today, it's solid piece of aluminium, looks very nice.
It's only looks like a raw cut, in real it is a very smooth surface.Coen said:memtew said:I've got mine today, it's solid piece of aluminium, looks very nice.
How does it look at the ends? Like the beavers did the cut (as per Festool photo) or is it good?
Thissix-point socket II said:Not going to argue about accuracy, finish, price. I consider this a gadget and in Festool Germany's shop it is listed as "fan merchandising" - and probably rightfully so. To me that says everything - along with a lot of the other stuff they list right there.
Weight 243 g. I assure you that this is a solid piece of aluminum.mino said:[member=73422]memtew[/member]
Looking again, are your serious this is indeed a machined slug of aluminum ? Can you weigh it possibly ?
six-point socket II said:Not going to argue about accuracy, finish, price. Also not going to argue about the Sys3.
However, it's a pretty neat solution to have a level with any drill/driver/installation-kit combo that will not exceed the Systainer(3)'s footprint.
If I would be using Sys3s, I'd probably get it, and ditch the much smaller level that I keep inside my kit. Accuracy should be well within the needs for such a level. At least from where I stand on this.
Kind regards,
Oliver
FestitaMakool said:Well, I got one - and I reeeeeaaalllly like it! [thumbs up]
First few tests it seems very accurate in both levels compared directly to my Stabila and Hultafors aluminium levels. So I wouldn’t hesitate to grab it for any situation (given it’s length of course)
- What a pleasant surprise!
It feels heavy (and are..solid piece of aluminium) in the hand with really high quality feel to it.
It’s got etched scales in Metric and Imperial (On each side) starts at zero at the end so you can bump it right into something and read out at the scale - Also accurate compared to a ruler I know is accurate, both Metric and Imperial (Yes [member=44099]Cheese[/member] also against my Starret.. [big grin]) Which makes it a useful ruler as well. It has a convex bottom and a flat top too, so it’s not completely rounded at the top.
It’ll even double up as a straight edge.
The green buttons are spring loaded and this even strengthen the feeling of thoughtfulness and quality.
So my advise, if you are thinking of it - get it!
Some photos: (The ends are smooth.. and square to the bottom)
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
So my advice, if you are thinking of it - get it!
